Hey gang
I'm looking at building a desk into my study which is fixed to the wall, sits on a frame made of 2mm x 1" SHS gal with a 3/4" melamine on particleboard or MDF top. Did one at the first place I owned and it worked well.
After thinking about different edges I've kinda settled on some options:
1. Iron-on sticky back laminate or veneer. Cheap, easy, looks like cheap and easy (ie arse).
2. Get some lengths of timber that matches the new flooring, get hands on a Triton or similar and route a 3-5mm radius on the top outer corner and chew out the guts to make an L profile which can be ??? attached to the front of the desk. Not sure how though: screw up from underneath on the foot of the L with liberal glue to the vertical?
3. Go the same way I went with the last one, using the grey plastic T molding and a borrowed router to cut the groove:
, but I've forgotten the place in Ossie Park I got this from the last time (it was 20 years ago) and no idea where to find it now.
I will be putting a shelf above the desk all the way around too, and overhead cupboards. Whatever I choose for the edging on the desk will be used on the shelf and, if it's the timber option, probably for the doors of the cupboards too.
Boxy types: any suggestions?
