M'soft Excel help required
  • M'soft Excel help required
    Need help PSB'ers.
    Currently running Excel (Office 2003) at this work location, and it's not behaving how I am used to.
    Example:
    If you select a row of cells (or column) that contain raw data, Excel normally provides a total of that data in the status bar (below the tabs at the bottom of the spreadsheet) on the right hand side.
    Problem:
    Someone has set this version up to only count the number of cells that I have selected. It won't give me a (running) total of the values in the cells that I have selected.
    Required solution:
    How the f*ck do I fix this?
    Originally posted by Viper
    I'm probably fucking something up.
    FOREVER RIDING WITH "DAVO" - FarRider #1
    http://forum.fjr13.org/index.php
    Administrator
    Where it say NUM down in the bottom right hand corner right click and select Sum (or whatever you want).
      Veefore is on the money.
        Brilliant....thanks Veefore (& Matso)
        Administrator
