Drilling walls and power line
  • Drilling walls and power line
    OK, I am going to hang my little cube speakers on my wall this weekend, but the problem is that it is above a power point (or near it)
    Is there anyway of checking if there is a power line in the wall cavity you are about to drill similar to a stud finder?
    or do power lines are pretty much runs straight up and down in the wall cavity?
    its a single brick wall
    sorry for the noob question...
    "Always look at where you want to go, never at where you are afraid to go" - My riding instructor
    If it's a single brick wall, there's no cavity.
    FTP
      Power lines in cavity walls run all over the place.
      Why do you need to drill right through the brick though?
      I rarely drill much more than 25mm and use wall plugs.
      Incidentally cables do run in single brick walls but usually only above light/ fan switches etc.
      Edit:- power points in single brick walls are normally vertical and cased in PVC conduit.
      If you can get up into the roof space you should be able to find it.
      DON'T TOUCH!!'
        err, ahh, conduit, if you or whoever built the house paid for it (or chased the GPO in later), not a standard thing by along shot!
          ah... I assumes that with the foxtel people and power line the bricks would be hollow??
          maybe i will use a smaller screw as the speakers are small
            DON'T TOUCH!!'
            This^^^ Most houses in recent times they just chase the wall, chisel out the brick, lay wires and plaster over :o I've also seen wiring AND water pipes run diagonally across walls (not fun when you hit one that should be miles away ) You can get testers that are like stud finders that show up any wiring though
            Originally posted by Phildo
            Originally posted by filbert
              I've got a water pipe that runs horizontal along the wall after the builder had to relocate a tap
              The moral of the story is, don't assume anything.
                how much would one of them gizmo cost?
                  One of these will tell you that there is power there. By no means foolproof however.
                  A lot of sparkies carry them.
                    Just turn the power off and use a battery powered drill.
                      However, it still may have power in it.
                      Will stop you getting a boot. Won't stop you busting the power cable in the wall and breaking your shit Which if it is single brick, will mean cutting into the wall, re-running the cable, re-plastering over, re-painting, etc...
                      Big pain in the arse.
                        True but the odds of actually hitting cable are fairly low.
                        Worse case scenario, chisel it out, repair cable, spakfill wall and drill another hole to hang a picture over the bodgy patched area.
                          actually my luck is pretty bad...
                          was going to drill a wall in the laundry... marked holes to drill... GF came in and said, why dont we move it a little to the left instead....
                          ended up drilling into my water pipe.... plumber came in and chisel wall out and showed me how small the pipe is, and how I just managed to knick the side of the pipe enough to cause a leak....
                          now everytime my gf does the laundry, there is a ugly unpainted section on the wall to remind her of her good idea
                            ^^ as per what he said. murphy's law applies. previous house i lived in, the owner drilled through a water pipe putting up shelving. my house, a guy drilled through my antenna cable fitting our range hood...
                              In a single brick wall, cables usually run vertically or near vertical (by law i think they can go about 50mm either way) in a chase.
                              If where you're drilling is more than 50mm for the most part you wont hit the cable...but then again you might!
                              turn the power off and hope you don't hit the cable, or else it may end up being one expensive hole
