R1 Parts
  • R1 Parts
    Where can one just walk into a shop n buy a -1 front sprocket and speedo healer off the shelf??
    Ideas pleased thanks in advance
    I ordered a speedohealer off Motomummy that I decided not to bother fitting on my 07 R1.
    Brand new. $70 if you want. Link
    For a front sprocket, try Total Motorcycle or Five Star Yamaha.
    If you love your motorcycle, set it free. If it comes back, you probably high-sided.
      Yep - Total Motorcycle had front sprockets ready to go for my gixxer when I walked in. Should be able to sort out your R1..
        Awesome is it a conversion or race? Do u know the chain pitch?? Seems its not that simple huh. Motorcycles for dummies edition on order
          Huh?? Are these questions you were asked or are asking us?
            you need to ask for race pitch conversion
            hehe
            Originally posted by Bendito
              They were questions i was asked. Might be better to buy a new set n chain. Too hard basket
                R1 Parts
                Do you have your manual? I got my chain pitch out of that - simple
                  Easy fit? Recon I could be interested. Went -1 front for now
                    standard r1 chain is 530 pitch, thin chain conversion is 520 pitch. sprockets must match the chain.
                      The 07's came with a 530 pitch chain and 17/45 teeth front/rear.
                      You'll need to check that the chain/sprockets have not been changed and remain as standard so that you get the right sprocket. There should be a number printed on the links on the chain. Check this to confirm.
                      Here's a link to the Speedo healer install on and 06. Pretty much exactly the same for our bikes. Just needs some basic tools.
                      How-To: 2004 Speedo Healer Install : Yamaha R1 Forum
                      Originally posted by redfern
                      It growls like a horny fat chick, screams like a drunk college floozey on a slingshot at spring break, and handles like mountain goat interbred with a gecko.
                        It appears to be a matter of just plugging it in. It is tiny, not much bigger than the cable. Never tried fitting tho, it is still in the packet. Couple hex keys to take the fairings off should be all you need. Fitting your sprocket will be way more work.
                        Check your rear sprocket and chain condition while you're down there. Could be worth replacing the whole lot.
                          Sprockets n chain just clicked over 13k still look original and in good condition, no wear evident. Ill change the rear at a later time when I do the chain
                          Busy tomoro mate for the speedo thing?
                          True plug n play or is splicing read bud?
                            Plug and play.
                            I should be home in the morning. PM me your number and I'll text you.
