Bent outdoor water pipe/tap.
Originally posted by Joe Shabadoo View Postseriously, the qualities of manhood seems to have developed an inverse relationship with the number of hipster beards
1. go to fucking bunnings
2. buy some stuff
3. apply stuff
4. if it pisses water all over the joint, restart from 1.
Why do you need to ask anything? Get some shit from Bunnings, replace the pipe. Have a couple of beers....The correct number of bikes to own = N + 1, where N is the current number of bikes you own.
I don't think that's going to bend back very well. Buy, beg, borrow or steal a map gas torch and cut the pipe at the lowest bend then solder new fitting on or Bunnings sell taps with a length of copper pipe attached buy that and a inline olive connector, will look average but cheap solution if your no good with tools.
I didnt know Yorkshire fittings, (pre soldered) were still available. A normal blow torch will work on those...I found dipping the pipe in flux prior to fitting the joiner helped the solder flow.Smoke me a kipper...I'll be home in time for breakfast
Originally posted by BusaSteve View PostI didnt know Yorkshire fittings, (pre soldered) were still available.Personally I'd Boycott them
Originally posted by PhildoNoted. We'll check back on that one in three yearsOriginally posted by filberti'll pretend you didn't know she was 13
Originally posted by BusaSteve View PostI didnt know Yorkshire fittings, (pre soldered) were still available. A normal blow torch will work on those...I found dipping the pipe in flux prior to fitting the joiner helped the solder flow.-
2. buy some stuff
3. apply stuff
What Joe said.
