CLick for Rules for Roadside Assist Section
STRICT RULES & INFORMATION FOR THIS SECTION:
WARNING: This is not a general discussion section. This section is reserved expressly for post started by those people in need of IMMEDIATE breakdown assistance. Please do not START a thread in here unless you need assistance. Any registered user may RESPOND to a thread started by the person who needs assistance, but no banter please, keep this strictly on topic so valid communications can be easily referenced.
This is not an accident or injury response section. If you have had an accident and are injured, please call 000 for assistance.
If you need breakdown assistance support from a PSB volunteer, please do as follows:
1) Ensure you and your bike are in a safe location to prevent exposure to damage and personal injury. If you are injured and need medical assistance, contact 000.
2) Create a new post in this section with the subject titled “Help Wanted – Suburb”.
3) In the body of the post please put as much detail as you are able including but not limited to:
(a) A good description of your actual location including street name, direction, nearest cross street, or any other information that you feel would be of assistance for someone trying to find you.
(b) Details on what the issue and the kind of assistance you need. EG: “Bike broken down, both bike and I require movement to Victoria Park”.
(c) Provide details of where you and/or bike need transport to.
(d) Provide your mobile telephone number if available.
If you don’t have a phone that has internet access to make the above post then contact someone who does have internet access and they can create a post for you.
If you are able, continue to monitor this thread for updates and responses.
What will happen now:
1) When you create a thread in this section an email is sent to all regsitered PSB volunteers automatically. It will also be monitored by those using the forum at the time.
2) They will visit this thread for details, and if able to respond will make a post accordingly.
3) If you have provided your mobile number, the respondent will likely make contact with you to let you know they are on their way and provide an ETA.
NOTE: This is not an accident response thread, meaning to say, if you have had an accident and you are injured, please contact 000 and ask for an Ambulance. This section is to respond to non life threatening or injury situations.
For the avoidance of doubt (and stupidity) do not post in this section if you are wanting help moving your bike somewhere were it does not relate to assistance required for an immediate breakdown need.
If you have a bike trailer or other facilities that could assist PSB Members who have broken down, and would like to register as a PSB Assist member, please email [email protected] from the email address you would like on the register so that you can be added.
See more
See less
Help - bike not turning over. cottesloe
  • Help - bike not turning over. cottesloe
    Hi all, need a bit of help was on the way to work when my gsxr 750 k7 gave up and died. Luckily this was when I just turned in. Problems are as follows:
    1. On the way in got cut off so horned but noticed the horn was weak with very little sound
    2. Just before it died my instruments failed - bike was still running and moving but rev meter was at 0 and the led speedo was frozen at 20km/h
    3. F1 light is now flashing and bike does not crank
    4. Oil looks full and there is no burning smell when cap removed to suggest lack of oil
    5. Is it a possible electric error? Lights are still coming on but maybe not enough power to crank?
    6. Bike has not been run much in the last 2 months and the last time I rode it was last week. Also should've idled it longer this morning but it still had a decent warmup. Bike is also due for a service.
    Any ideas? I'm stuck at work till 12 so can't really go out to it much too. My mob is 0423 051 242. Any help or suggestions is very much appreciated!
    How olds the battery. Could be shot.
    Would explain a few points there.
    :aus-salute: Yer thats ULTIMATE :aus-salute:
    Originally Posted by lobes89 View Post
    Yea I like the bike but it's hard to get my foot under the brake lever
      Sounds like a dead battery and/or malfunctioning charging system. Do you have access to a battery charger at work? If so, I'd plug it in and let it charge while you can. If after a couple of hours it starts, continue to charge till quitting time then ride it home. Once there, you can figure out who's gonna fix it. If you don't have a charger available, I'd be looking for a ride.
      Hope this helps in some way. Good luck.
        Good point Jacko, 3 years now that I think about it. Will try and get my hands on another battery after work and see if that fixes it
          Battery...if not run much as you say then a battery tender is the way to go. You may be lucky and find the battery is OK but they do not like being run flat...it shortens their life.
            Thanks guys, battery makes sense, would've bought a drip charger if I knew I'd be off it for a while. Will bum a lift and go get the battery checked.
            Thanks for all your reaponses, this thread was a lifesaver!! Really appreciate it
              To me it sounds like a Regulator Rectifier or the alt - maybe a stuffed stator.
              You may find it'll start ona new or re charged battery but die once the charge runs out.
                check the battery contacts.
                may have corroded slightly. Give them a clean with a wire brush.
                Have you won the game recently?? Post here
                  I would not jump straight in and suggest any of the charging system is faulty...simple test is to fit the battery when charged ...if it will take one... run the motor and check across the battery terminals with a multimeter set to around 20 Vdc. You should get a reading of around 13.5 Vdc. Increase the rpms to around 5 thou and the voltage should rise to about 14.5 to 15.
                  Points to ponder...........
                  Battery boiled dry... regulator may be suspect.
                  Battery goes dead...short or fault with alternator or rectifier.
                  Good luck
                    I can come buy and have a look if your keen. Im on night shift for the next 2 weeks so can come by in the mornings.
                    John.
                      Update - took the battery home and got it charged at dads work. Battery was dead but the recharge was sufficient to get the bike home yest. Will do the above checks as suggested tonight. Hopefully just the battery as it prob didn't get a proper charge as the bike wasn't ridden much.
                      John will let you know after tonight, thanks.
                      Thanks all!
